Dave Rae avatar image
Dave Rae asked
Pylontech battery earthing
Hello, I am installing Pylontech batteries and cabinet on a DC coupled system, multiplus 2/48-5000... I noticed that there is continuity between the negative battery terminal and the Earth point on the battery case, which is then grounded to the case with the supplied earth cables. The battery cases Earth point, does this need a separate Earth rod/point or does it share the same Earth as the inverter and AC system?
Thanks for your answers....
battery
ewalderasmus avatar image
ewalderasmus answered ·
@Drae
Hi Drae, in sort the earth stud on the Pylon tech is for earthing the mounting brackets, you don't need a separate earth rod for that.
Hope this helps.
Ewald
