cadams avatar image
How do I choose which MPPT Controller I need?
Having difficulty figuring out what controller I will need for my solar power boat project. I’m hoping you can help me.
Here is my set up:
(4) 12v deep cell gel batteries 100ah (series)
(2) 100w solar panels with these specifications.
Renogy 100 Watt 12 Volt Mono Solar Panel(Compact Design)
Solar Cells: 33 Cells Cable: 14AWG (2ft long)
Junction box: IP65 Connector:s MC4 connectors
Maximum Power: 100W Maximum System Voltage: 600V DC (UL)
Optimum Operating Voltage (Vmp): 17.9V Open-Circuit Voltage (Voc): 21.6V
Optimum Operating Current (Imp): 5.72A Short-Circuit Current (Isc): 6.24A
Cell Efficiency: 21% Max Series Fuse Rating: 15A
Weight: 16.5lbs Dimensions: 42.2 X 19.6 X 1.38 In
charge controller compatibility
cadams avatar image
cadams answered ·
I was informed by the tech staff to go with the 100/20 48v model.
Since I have (4) 12v batteries hooked up in a series.
Can anyone tell me as far as install, do I need to hook the positive up to battery#1 and negative up to #4?
oh, you are right didn't saw that. So you need the 100/20_48V.
And yes, you have to use the positive of the first and the negative of the last battery.
JohnC avatar image
JohnC answered ·
Hi @CAdams
The issue you face now is the panels. Those you cite, you'll need 4x of, series-wired to give you enough V to charge 48V batts. There's not much wiggle room with the 100/20_48, so consider carefully what you choose.
