xaveer avatar image
xaveer asked
"Charge only" drains starting battery
I have a MultiPlus 12 | 800 | 35. With Corono the bus was just standing there for days. After say 4 days I found that my starting battery was drained (also auxiliary battery). That happened at least 3 times. Then I saw that the MultiPlus was set to "charge only". After switching to "off" no more problems.
All the time the car was not connected to an external AC source.
battery
Rob Fijn avatar image
Rob Fijn answered ·
Hello @xaveer, this is very good possible. The datasheet of the 12/800/35 say "Zero-load Power" is 7 Watt. This could drain your battery over a few days.
Regards, Rob
xaveer avatar image xaveer commented ·
Thanks Rob
