Dave Rae avatar image
Dave Rae asked
Do I need a Lynx shunt with Pylontech batteries?
Hi, I'm installing pylontech batteries and ccgx color control.
Multiplus 2. 48/5000...
I have a lynx shunt, is that still worth installing and interfacing with the ccgx ? Will that clash with the pylontech bms?
Or just stick with the pyramid bms....
Thanks for any advice.... Dave...
lynx shunt
mvader (Victron Energy) answered ยท
Hi, I recommend to leave the Lynx shunt out.
it can indeed clash on the canbus when share with the Pylon, and there are more issues.
Lastly, you dont need it. Adding a shunt next to a managed battery like Pylon, even when on separate canbusses, is something we advise against.
10 comments
Dave Rae avatar image Dave Rae commented ยท
Thanks for your quick response appreciated....
0 Likes 0 ยท
Cansin Sari avatar image Cansin Sari commented ยท
Hey short question,
Can I see the voltage current soc of the batteries without the shunt, only with pylontech BMS?
0 Likes 0 ยท
mvader (Victron Energy) avatar image mvader (Victron Energy) โ™ฆโ™ฆ Cansin Sari commented ยท
Hi! Please read the victron / pylontech manual
0 Likes 0 ยท
Cansin Sari avatar image Cansin Sari mvader (Victron Energy) โ™ฆโ™ฆ commented ยท
Thanks. I already have red it. But I want to know, if I can display a diagram of the SOC course/progress and not just only the current SOC (without using a smart shunt).
0 Likes 0 ยท
seb71 avatar image seb71 commented ยท
Would that advice also apply for a SmartShunt/BMV (which uses VE.Direct to connect to the GX device)?
0 Likes 0 ยท
Cansin Sari avatar image Cansin Sari seb71 commented ยท
+1
0 Likes 0 ยท
hi seb, yes same for that.
A Pylontech, and a BYD, and any of the other CAN-bus connected batteries all have internal shunts, and report voltage, current, SOC and more parameters. And those parameters are all visible in the UI of the GX Device as well as on the VRM portal.
history as well.
Adding a second shunt aka battery monitor to it in series, such as BMV, SmartShunt, Lynx Shunt or otherwise, will only serve to create confusion. "Why is my SOC not the same, why am I seeing 70% here and 90% there?" and so forth.
So, don't do it. If you have a managed battery, don't install a BMV or other battery monitor alongside.
0 Likes 0 ยท
Thanks for the clear answer. You are great! I wish you a good day.
0 Likes 0 ยท
Guy Stewart (Victron Community Manager) avatar image Guy Stewart (Victron Community Manager) โ™ฆโ™ฆ mvader (Victron Energy) โ™ฆโ™ฆ commented ยท
"A man with two watches is never sure the time"
0 Likes 0 ยท
evillanueva avatar image evillanueva mvader (Victron Energy) โ™ฆโ™ฆ commented ยท
Hello, I have a question regarding this. Is it also not recommended to use a shunt+BMV only for monitoring, i.e. not connected to the CCGX? will it bring any problem?
In this installation, the CCGX is in one building and the final user is in another one + no internet connection for VRM portal, and I need to monitor the SoC in this other building as well.
BTW, I have used the BMV with long comm cable before with good results
0 Likes 0 ยท
