Ben Stanton avatar image
Ben Stanton asked
Is Adaptive + Battery Safe suitable for Lead Carbon & Lithium Batteries with Lower Absorbsion Voltage than 14.4V?
The Help File in VE.Config states that "The absorption phase will start when the voltage reaches 14.4V (for a 12V battery) regardless of the specified absorption voltage"
Does this mean that if the Absorb Voltage is set LOWER than 14.4V the system will this push the voltage to 14.4 (or 57.6 in a 48V system) Volts and then drop back to the Absorb Voltage? If so then should this setting be avoided for batteries with a Lower Absorb Charge Voltage requirement such as Lead Carbon or LiFEPO4 with no external BMS control?
battery charging
