trevor-2020 avatar image
trevor-2020 asked
Phoenix charger only fault?
  • Hi. I'm a liveaboard narrowboater and am currently using shore power. My inverter works fine with the rocker switch in the on position, but appears dead when in charger only mode. No warning lights nothing appears to have tripped off. I also have solar panels and the batteries are receiving charge OK from them and also when I run the engine. Just not from the shore power. Any suggestions?
battery charging
bruces avatar image
bruces answered ·
Do you have the remote knob turned up to full? If it is set to (say) 10A & you are using 15A then it will use the incoming 10A for your usage with none left over for charging.
Which remote do you have? Just been though a similar exercise here.
