eirik avatar image
eirik asked
Argo FET 200 capacity
Hi, In my boat I am adding a Delco 28Si alternator which supposedly is capable of giving up to 250A. I could reduce its output to around 180A-200A, but it might when starting and for a couple of minutes nevertheless yield up to 250A. Is the Argo FET 200-3 capable of handling this current? I.e. is it OK to exceed its rated specification of 200 A for either longer or shorter periods?
There will be three battery banks connected: 600 Ah LiFePO4 House bank and 200 Ah +105 Ah AGM banks for thruster and starter, respectively.
Thank you.
Eirik
battery chargingArgo FET Diode
