BenM avatar image
Orion connected to Argo
Does the Orion 24/12/9 work correctly when connected to a Argo?
With other words, the Argo dont see a voltages at starting up, because the Argo is in between the Orion and battery.
There are 2 isolated batteries connected to the Argo.
Or do I need to use 2 Orion 24/12/9
orion converterArgo FET
Johannes Boonstra (Victron Energy Staff) avatar image
Johannes Boonstra (Victron Energy Staff) answered ·
Not sure if i understand the question. The Orion is directly on the battery, so that will work. And on this Orion output a Argo is connected which sees the voltage of the Orion, so will also work.
Share
