Gauge readout shows 13.84v and at battery 13.91v
Can anyone tell me why as I have lithium set up and need more accurate readings for float etc
Cheers
Geoff
Cheers
Geoff
A couple things come to mind:
1) There might be a difference between the BMV700 and the multimeter you are using to measure at the battery. Measure with your multimeter at the shunt to see if there is a difference there. If so, try another multimeter or just chalk it up to 0.5% error.
2) If current being drawn from the battery the voltage at the shunt WILL be lower due to voltage drop in the cable between the battery negative terminal and the battery terminal on the shunt. Minimize the length of this connection and make the wire as large as you practically can to avoid this drop.
13 People are following this question.
