I saw the blog post for a new firmware update for the Multplus-II, but it doesnโt appear on our IOS VictronConnect app. How come?
If it is that urgent to update the firmware, than use VEflash instead of VictronConnect.
https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
But for this you have to download the firmware file from the Victron Professional Portal.
https://professional.victronenergy.com/
There you get the very last firmware 473.
We donโt have windows laptops, only Macs. Weโre having trouble with the inverter shutting down prematurely (e.g., saying low voltage with it isnโt) and weโre hoping this update solves the problem. Weโre also not installers, weโre the system owner.
The firmware update will also wipe all settings, requiring reconfiguation of the system. It is protected by a password and only intended for trained installers.
Please contact your installer and discuss the system issues with them first, before trying to fix it yourself by doing firmware updates and such.
I just tested the firmware update procedure with VictronConnect version 5.20 as described in the VictronConnect manual, and it worked and offered my MultiPlus-II an update to 471.
14 People are following this question.
