Bobby avatar image
Bobby asked
Victron Multiplus II 48/5000 (noisy) Fan Replacement
Hi all, as per the topic, I own Multiplus II 48/5000/70, with MPPT and a 48V battery bank.
Things are working as expected, so no problems with configuration.
The Fan also switches on when having a load of around above 2kw for more then 30-40 seconds (and I also believe that that is in order). However - I am not confirmable with the noise of the actual fan - the thing is loud and I do know that there are many fans on the market that have different bearings in order to lower the noise.
Can anyone advise if the fan in question is 24V DC or 12V DC and confirm the dimensions (if I'm not mistaken, it should be 120x120x38mm)?
Thanks in advance
Bobby
Multiplus-II
Bobby avatar image
Bobby answered ·
Ok, so I found a possible replacement(s)...I understand that it is less thick, but that is not that important as diameter and flow rate...
Noise however is significantly less.
Only thing I'm not sure is which exactly fan is inside of the Multi II ?
The replacements (Noctua Industrial 120mm)
Also, the connector PWM has four contacts but it can be modified to two only so that won't be an issue
Rob Duthie avatar image Rob Duthie commented ·
Hi
You need 110CFM or 186 m3/h flow rate
Model in Multi is a JF1238B2HR-R
24v 110CFM 2800 RPM dBA 43.50
They have s similar sound rating. all depends on the fan blade design if you want quieter fan noise. slower rpm as well with the correct blade design.
There are many other known fan brand names out there.
Bobby avatar image Bobby Rob Duthie commented ·
Thats exactly the brand i posted the screenshot for...
Not sure why it didn't show
Based on the db rating, they would generate the same noise level :(
I wonder it the pitch of the noise would be different
Pierre-Marie Baty avatar image
Pierre-Marie Baty answered ·
I'm resurrecting this old thread for other readers to share my experience.
I have a Multiplus-II GX and I too find that fan noise absolutely excessive. I have applied stenis' advice and had taped bitumen mat on the inside of the housing cover, to find out that it had only improved the problem marginally -- i.e. when you're in front on the device. The situation is not improved when, as in my case, the enclosure is hung on the wall (a *concrete* wall) that separates the house from the parking garage : it can be heard from everywhere in the house !
I too have searched for fans with similar characteristics and found none that would be allegedly quieter, at least on their datasheet.
The vibrations induced by the fan activity are just absurd ; even its neighbour the Fronius inverter saturated with solar power generates less than half of that noise.
Moreover, the problem has gotten significantly worse since I upgraded my MPII firmware from v470 to v490; with the old firmware, the fan would only kick in when the device was sending to or drawing power from the battery and stay quiet in passthrough mode - now it spins even in AC passthrough mode, when all the power on the output comes from the grid input ! This is ridiculous and infuriating.
In my opinion the last thing that would work, apart from moving the enclosure far away from the house which is unacceptable, would be to create a forced air duct, well fitted to the enclosure's air intakes, long enough to breathe air from the outside, and deport the fan all the way there.
I see no other solution, apart from enabling that "silence fan" configuration assistant which has the big drawback of reducing the inverter power.
This annoyance is, IMO, by far the #1 negative point of these devices, and if I had known they would be so noisy I probably wouldn't have bought one. Buyers beware.
Rob Duthie answered ·
Hi
Their fans are noisy in those units even from day 1, yes there are 120mmx38 and are 24v.
It's to do with the blade design etc to have a low noise fan, this fan might be middle of the road type? As i side note this is the company that has made capacitors for years, not fans.
They are ball bearing type. Brand Jamicon data sheet attached.JF1238-14.pdf
Regards
Rob D
NZ
jf1238-14.pdf (388.5 KiB)
Bobby avatar image
Bobby answered ·
I will try and find some replacement with lower noise (db) and attempt to change it...
The noise of the factory fan is just too annoying and loud
Deon avatar image
Deon answered ·
I have an EasySolar 48V 5000VA and it is extremely noisy
With an uncalibrated phone based noise meter, my Easysolar measurements are:
1 - Silence - 20dB
2 - My workspace - 50dB (EasySolar fans at full speed)
5 meters from
the Easysolar
3 - 1m from blue encl. - 60dB (fans at full speed)
of the EasySolar
4 - Outside the encl. - 80dB (fans at full speed)
at hot air outlet
The current fan JF1238B2HR-R, gives a spec of 43.5dB, which means the position of fans in the blue enclosure is the noise generator. I have not opened the enclosure to understand the noise sources.
I need some advice - do I replace these fans, and will it affect the warranty?
The alternative is to have the Enclosure moved, and the associated costs and additional wiring.
Nickus de Vos avatar image
Nickus de Vos answered ·
Not specific to Victron, but in general the perceived fan noise of equipment is mostly contributed by vibrations threw the chassis rather than the fan itself. I'll put some good money on those fans being a lot quieter if taken out of the inverters and measured in free space. Often you can get rubber mounting systems for fans which helps a lot, pads, washers, screws etc. A good fan manufacturer like Noctua should sell some of these accessories. Best I think will be to buy a bunch of accessories with a good replacement fan then open up the inverter and see what you can do in mounting the replacement fan with some rubber accessories. Often something simple like rubber mounting screws in place of metal or plastic can make a big difference, or just ensuring that the mounting screw doesn't touch any other part like the chassis or cover.
stenis avatar image stenis commented ·
I tape a bitumen mat on the inside of the housing cover, this reduce the vibration quite a lot - easy and cheap solution :)
popnic avatar image
popnic answered ·
@Bobby I had a chance to compare different fans with same voltage, amperage, and size. The Jamicon model - thank you Rob for sharing - that is in MP2 was the one of the most powerful form air flow perspective. From noise perspective you can hear mainly the air flow from the Jamicon fan when it is supplied with DC or high freq PWM from 20 to 24V.
Unfortunately MP2 need a hi flow fan to cool down especially the transformer and also the MOSFET's and choke due to "redesign".
I visit a showroom to discuss the fan noise issue. @Deon similar measurement results. There one unit MP2 was with fan on and it was also loud. I convince a technician to remove the front panel and he did it. We were surprised about the difference. With the front cover off the noise was way less but when he put the cover back, the noise comes back at high level again.
If you change the fan i think that you will loose the warranty but if you still want to do it, in my opinion you have to address to:
- noise source - fan itself - change with a better one with same flow rate;
- fan speed control hardware - low frequency PWM - add a basic RC filter;
- mounting bracket - transmit vibration to the housing - add a damping material under it and between the screws and housing @Nickus de Vos Victron should consider your remarks.
- housing - being half empty it resonate like an acoustic guitar - here you have to be careful because also the housing has an important contribution to heat transfer. @stenis good ideea.
Having some experience in NVH from one of my previous job I can say that this kind of issues are not so easy to solve and has to be considered in the design phase which, unfortunately was not the case.
Good luck!
19 comments
iand avatar image iand commented ·
I don't understand why Victron don't use a continuously-variable-speed fan (temperature-controlled) like in PC coolers instead of simple on/off -- this wouldn't make any difference at high loads (say, over 60% of maximum power) but could make the units much quieter at medium loads (say, 20%-60%) where they spend most of their life. It's only the last part of the fan speed curve where the noise goes up rapidly, at medium speeds they're *much* quieter.
Any comment from Victron about why this is, and whether it could be added in future via a firmware update?
Rob Duthie avatar image Rob Duthie iand commented ·
Hi iand
The fan speed is controlled depending on the temperture of the transformer and switching electronics.
One note when at lower speeds they are more noisy due the PWM controller.
Regards
Rob D
NZ
kevgermany avatar image kevgermany ♦♦ Rob Duthie commented ·
Rob, I fitted Noctua PWM fans to cool my batteries. Tested before installing. They're completely inaudible until about 60%. So although older ones may be noisy at low speed, good ones aren't.
Rob Duthie avatar image Rob Duthie kevgermany ♦♦ commented ·
Hi Kev
You say you fitted a Noctua PWM controlled fan in the multiplus and it is a lot quieter the orginal ones? what about airflow rating compared to the original ones. I see that they only do 24v ones in a industrial version. and very simalar air flow rates.
They are half the db noise rating of the Jamicon ones and also have included damping etc.
The fans that are mounted in the Multiplus2 are hard fixed with no damping to the frame to keep vibrations and resonates down. That is what part of the issues appears to be. Just done a quick measure of the PWM when fans is running slow the PWM is 50Hz at 8v DC and has quite a virbration to it, after fitting a crude capacitor filter across the motor connection it does make it less noisy but not by much, it sounds like the fan motor dose'nt like running at the lower speeds not realy designed for PWM applications signals, The fan like the Noctua is better suited to this application of PWM control.
I have one on order here in NZ to replace and report back on my findings
Regards
Rob D
NZ
popnic avatar image popnic Rob Duthie commented ·
@Rob Duthie I did an experiment on a testbench with Jamicon fan. I played with PWM frequency from 30 to 50Hz as you mentioned and different duty cycle at 24V . I got good results with a 10W 33Ohm series and 1000uF in parallel on the fan side.
I choose 33Ohm from 27, 33 and 47 ohm as a compromise for rpm of the fan and less noise.
27 ohm the PWM is noticeable. With 47 ohm the fan is running smooth but rpm is too low.
I do not want to open my Multiplus II because the option to send it back is still available.
Ron, can you experiment this for me in real conditions?
Thank you.
Nope, as coolers to shift some air over my batteries. I designed the compartment very badly and there's no convection.
The 50Hz explains the noise differences. I didn't try running the Noctua's at low frequency. Just decided to stay with their specs. Apparantly Intel said 30KHz to keep PWM noise inaudible. And that's the PC standard.
What I also noticed was that the smaller fans make fan noise earlier than the bigger ones - if my English makes sense.
kevgermany avatar image kevgermany ♦♦ kevgermany ♦♦ commented ·
But I must add that it's important to use PWM at the PC standard of 30KHz.
Hi Kev
Yes i don't think Victron are running at the higher frequency rate thats why they are noisy at low fans speeds this i have noticed on a few installs i have done with multiplus2 inverters to date. even the older modles the multigrid models as well.
So i have on order a Nocua fan to replace it in my unit to see what the difference it makes. as it has rubber damping mounts compared to the Jamicon brand which is hard mounted to chassis with no damping at all, so it will resonate in the enclosure which interns makes it sound very loud when running at lower speed so i will use my inverter personal as a dummy test unit, as i have a complete system setup with Vicrton gear etc to test these issues in real time applications in my workshop which is connected to the house.
Regards
Rob D
NZ
n-dee avatar image n-dee Rob Duthie commented ·
Which one did you order?
This one is looking really good:
Noctua nf-f12-industrialppc-24v-3000-q100-ip67-pwm
br,
Andy
Rob Duthie avatar image Rob Duthie n-dee commented ·
Hi
Thats the one.
Please let us know how you get on.
Some time ago I posed a question to @Johannes Boonstra (Victron Energy Staff) in his YouTube tech talks about fitting a quieter fan, his reply was the fairly predictable yes, but at your own risk and I've a feeling he also said it would invalidate the warranty. Obviously not a problem for you, but if anyone's reading and decides to try, be aware. I haven't taken it further yet. Might do. If the standard fan is low frequency PWM, I guess I could rig up an Arduino to convert that to 30KHz. But mine (compact in an easy solar) is quiet enough unless there's a big system load.
Hi Kev
The Noctua fan won't realy start until the PWM is at higher output. I used a fan from a Dell server as well which are realy quite fans, the PWM comming out of Victron is crude to say the least, This made the DELL fan noisy as well, by the PWM pulses. On a normal varible regulated PSU super quite even the standard fan was very quite but soon as you add the Victron PWM noisy as.
I have added a 220uf cap across the motor output which has smoothed out the PWM and fan doesnt resonates no where as much. Also if i rubber mount the fan it will be even more quiter.
I do have a PWM generator i can change the Freq and Duty cycle which runs motors on to see were the sweet spot is. What we need is PWM output converter to voltage output filter.
Regards
Rob D
NZ
Thanks Rob, good try, explains a lot.
Pierre-Marie Baty avatar image Pierre-Marie Baty Rob Duthie commented ·
Very interesting. I'd be very curious to see what that "crude" PWM signal out of the Multiplus mainboard looks like on an oscilloscope, measured in time and frequency (FFT). Once we know what it really looks like, I bet something can be done to improve the problem !
Rob Duthie avatar image Rob Duthie Pierre-Marie Baty commented ·
Hi
Around about 50Hz when running at slow speed or about 8v.
I was more thinking in terms of signal cleanliness and harmonics but thank you nonetheless.
The PWM is a clean signal, just the motor can't handle the low freq PWM signal, its to low so it makes the motor pulse and be noisy, needs to be set at a higher freq rate to smooth out the pulses. i am not sure if it controller by a micro or not if it is, a software firmware update will fix it?
OK so if the signal is clean and the frequency is unsuitable for the motor, and considering the motor is wired with 2 wires (which means it should be able to be driven by a continuous signal), then the lowpass filter (popnic's method) is the best that we can do. That will effectively transform the PWM square signal into a quasi-continuous signal ranging from 0V (PWM = 0%) to Vcc (PWM = 100%)
Show more comments
baxter avatar image
baxter answered ·
up to know I thougth the fan is just voltage controlled, has it has only to wires (+ and ground).
Are there new multiplus II with a pwm controlled fan?
9 comments
Hi
The multis have all being PWM controlled 2 wire fans, since day one, As i have owned a the older version and the newest versionof multis and all have the same noise issue at lower speeds etc.
Regards
Rob D
NZ
baxter avatar image baxter Rob Duthie commented ·
For a PWM controlled fan 4 pins are required, at least for the Noctua Fans (and all fans I use in the PC settings).
So how to connect a 4pin Noctua PWM fan to a 2pin Multi? I guess there will be no PWM signal and the fan is only voltage controlled.
https://noctua.at/pub/media/wysiwyg/Noctua_PWM_specifications_white_paper.pdf
Pierre-Marie Baty avatar image Pierre-Marie Baty baxter commented ·
Actually it seems they used an electronic trick, where the Jamicon fan is driven analogically with a PWM square signal that is lowpass-filtered by the fan hardware itself into a quasi-DC signal between 0 (when the PWM is at 0% duty cycle) and 24V (when the PWM is maxed out). The Multiplus fan is not really a PWM-driven fact in this regard, just an *analog* fan that's driven with a PWM circuit, instead of a DAC - probably because it's cheaper.
If you want to plug your Noctua, you'll need to use the blue, yellow and black wires. Tap a 24V DC somewhere from the mainboard to the yellow wire, match the black wire (ground) with the black wire, and send the red wire (PWM) through a dividor bridge that will lower the 24V PWM square signal from the Multiplus into a 5V PWM one compatible with your fan. That's how I'd do it.
*edit* sorry for my bad english ; by "dividor bridge" I meant this : https://en.wikipedia.org/wiki/Voltage_divider
baxter avatar image baxter Pierre-Marie Baty commented ·
Thanks for explaining this.
How weird is that
Actually it's a rather common trick.
Choose your resistor values wisely: to bring down 24V PWM to ~5V, you need Z1 to be 4 times the value of Z2 (ex: Z1 = 4k ohm, Z2 = 1k ohm).
Hi
That will work Ok just trying to avoid any soldering on the PCB and make it a plug in play type fix.
I am trying different T filter to see how to smooth out the pulses to the motor. So far not the best solution, just a 100 to 220uf cap makes the most difference but the fan runs faster of course.
I have used a PWM generator test rig to run a Noctua fan at the lower 1KHz PWM runs very smooth and is better at the 25kHz range better linear control down lower At the lower end of my PWM tester it won't go that low to test at the same as the Multiplus, need to change to re test at the 25Hz range same as the Multiplus.
Regards
Rob D
NZ
kevgermany avatar image kevgermany ♦♦ baxter commented ·
The fourth wire is PWM in. Three wire fans omit this and simply feed the actual fan RPM back. Speed control is by voltage from the controller, often/usually in the form described by Rob - i.e. a PWM signal 'smoothed' to give a lower voltage overall. Hence they were called PWM, but.... The fan didn't read the PWM signal like the 4 wire fans do.
baxter avatar image baxter kevgermany ♦♦ commented ·
Will the Noctua Fan work with just 2wires like the original one (only +24V and gnd) ? Based on the info I got from Noctua support the fan also supports voltage control without PWM Signal in.
Rob Duthie avatar image Rob Duthie baxter commented ·
Hi Yes it does.
iand avatar image
iand answered ·
I still don't understand why Victron do such a lousy job of fan speed control -- every single PC on the planet has proper HF PWM control to give quiet variable-speed fans and the circuits to do this cost next to nothing, so why on earth don't Victron do the same? And mount the fans on little silicone feet like Noctua do, the cost is pennies but it makes a big difference to noise from the case...
I'm not trying to justify anything but from a different perspective:
Current system works and is reliable and well proven
Many installations are in places where noise isn't a problem
More consistency in parts for maintenance
Other development priorities
Perhaps high frequency PWM wasn't as common when this was designed
Change is high risk-get it wrong and a huge number of units will give failures in the field.
All fans, even the super quiet ones, develop a lot of wind noise at higher speeds. The alternative is to fit much bigger fans at the cost of bigger units.
Having said that, I'd love the unit in my camper to have a much quieter fan. At all speeds.
iand avatar image iand kevgermany ♦♦ commented ·
HF PWM has been ubiquitous in all PCs for many years, the risk of any problems are probably lower than the existing solution, cost adder is close to zero.
The cost adder for bigger fans is negligible in the context of overall product cost -- if you want to be quieter and can fit them in they're quieter, but the product has to be designed for them -- which is too late for MP II and Quattro II.
Well, it seems clear to me that vibration dampening and keeping sound levels acceptable were
*never* considered at all as possible issues by the designers of these products. It's to a point that many design choices that have been made were in fact the worst ones in this regard.
Now to recover from here... Apart from the forced air duct, or redesigning the enclosure completely and retrofitting the boards into a carefully hand-crafted one, I don't even think there's a proper solution.
I'm still watching this thread in the hope of a miraculous idea, but I'm slowly pushed into thinking it's a waste of time. Currently I live with it.
popnic avatar image popnic commented ·
I contact Victron about fan noise issue. They come back to me thru distributors technical representatives in a day. They were fast and they listen me but we come to the conclusion that the unit is not faulty so the service is not necessary.
We are only a dozen of "sensitive" people here but remember:
Victron is powered by Multiplus II's and this is why they cannot hear us.
Personally I will not change anything in my Multi. It is a good product but is not for me. I lost the opportunity to send it back so I will keep it while I am looking for another inverter/charger.
Sorry to bothering you guys.
Hi Bobby
I have modified a my own Mulitiplus2 unit with a Sunon fan 25mmx120mm model # EEC0252B1-0000-A99 with rubber mounts and with 47uf 63v cap across the fan terminals. And results are, the bad droning noise or PWM noise due the low PWM frequency you normaly heard has gone.
Much quieter unit now, no droning like before. just air flow noise though the unit now which is much more pleasant to listern to.
The air flow is the same as the orignal Jaicon fan, the 25mm thick fan allows for the rubber mounts to used on the original mounting bracket.
If Victron could just change the PWM to a higher frequency rate the problem would go away , and they would have a much quieter inverter on the market.
Regards
Rob D
NZ
14 comments
mondeoman avatar image mondeoman commented ·
I can also confirm that the recommended SUNON EEC0252B1-A99 (EEC0252B1-000U-A99) fan is much more quieter than the original fans of the Multiplus-II.
The fan is available on the SOSElectronic website in EU and is cheap.
I used a 220 uF capacitor because at 47 and 100 uF I could stil hear some "vibrations" from the PWM at low speeds.
Pierre-Marie Baty avatar image Pierre-Marie Baty commented ·
Excellent ! I'll try this model just like you did as soon as I have time to open that Multiplus-II again. And thank you for the pictures. Out of curiosity, what does the dB-meter say compared to the factory setup ?
Hi
Didnt not have a dB meter, just it is much quieter than before no droning noise.
raymiller avatar image raymiller commented ·
Thanks Rob for getting to the bottom of the fan noise issue and providing some solutions, I have been wondering why my Multiplus 2 fan noise is like no other piece of equipment I've come across in my 40 years in electronics.
It would be good if Victron could bring out modification kits (hardware and software) to sort this out once and for all.
I'm not sure your noise isolation mounting is as effective as it could possibly be? Is the bolt and nut fully isolated?
Rob Duthie avatar image Rob Duthie raymiller commented ·
Yes it is, the rubber damping is the isolation. it way better than the stock fan setup. It boils down to Victron to just change the PWM pulse to much higher frequecy rate and problem goes away, simple as that, i have tested with a higher rate and is much quiter on the standard fan. As there PWM pulse rate is only 25Hz too slow thats is why the fan drones.
Regards
Rob D
NZ
kivanov avatar image kivanov Rob Duthie commented ·
Hi Rob, can this be fitted with the MP2 on the wall, or it has to be taken down on a bench?
Does it make sense to place 100-220uF cap instead of the 47uF (like suggested by mondeoman) in the in the context of fan effectiveness (when high speeds and air flow is needed, t.e. heavy loads), especially the possibility to pass the fan voltage limits?
Rob Duthie avatar image Rob Duthie kivanov commented ·
Hi
Need to take down and remove the fan bracket to fit the fan etc. 100uF will be fine.. With the higher capacitance it make's the fan run slighty faster at the lower speeds that all.
Regards
Rob D
NZ
Hi Rob, thanks for your time with this and your answer.
Having look at the datasheets of both, the original one (Jamicon JF1238B2HR-R) is rated at 118CFM, while the Sunon EEC0252B1-000U-A99 is 108CFM.
The Sunon max current rating is also (0.238A) compared to the 0.31A of the Jamicon.
I suppose that your experiments did not show anything near the limits, so this can be safely be replaced?
p.s. Just to add the original fan connector to the MP2 board is H2P-SHF-AA. This should be a variation of JST 2.5mm pitch connector.
Hi Kivanov
Yes that is correct, to date no issues, just a much quiter inverter system now.
I do this for all my clients to date due to the noise issue they complain about, as it runs slighty faster at the slower speed it cools down better, this is due to the capacitor interaction with the PWM pulse.
Regards
Rob D
NZ
maa avatar image maa commented ·
Well done
michaelvh avatar image michaelvh commented ·
Nice work @Rob Duthie , how did you find the noise improvement by using the Sunon fan and rubber mounts but without the capacitor in between, if you tested this? Was the droning noise just as bad as before?
Rob Duthie avatar image Rob Duthie michaelvh commented ·
Hi
Only with a cap as this helps to smooth further the PWM pulse.
Regards
RobD
NZ
I added an extra supporting bracket (and a third rubber mount to the top of the fan) to stop the fan from sagging when the Multi was wall-mounted. This also allows for the mounting of the capacitor on the mount.victron-mulit-fan-mod-img-2909.jpg
I need to add an extra supporting bracket made from right angle aluminiumvictron-mulit-fan-mod-img-2909.jpg and a third rubber mount to secure the fan.
ecoman avatar image
ecoman answered ·
Hi folks, first time posting here. I also belong to the surprised, noisy Multiplus II owners club, mine is the biggest 10kW version. I almost fell off my chair when I heard the fans starting the first time. That was under a light load of about tad over 2kW which one would think to be easy for a 10kW unit (well, maybe 8kW instead of 10kW name tag) but anyway, only a fraction of max. The unit is brand new, and naturally Victron will not consider faulty, so no warranty claims to be done. As such, I am considering the same modification as you have done - but one thing caught my eye in the SUNON EEC0252B1-A99 (EEC0252B1-000U-A99) fan mentioned in this thread. The fan spec says the following, and I would like to hear how do you read and understand it.
On page 11 of the spec, they tell not to use PWM control with it:
Ie, the way I read it is that the fan has only two pins, power and ground, and neither of those should be used with PWM signal. Wonder if it means the fan will die prematurely without warning, or smth else? Should we find another fan which is ok for PWM control?
Thoughts?
4 comments
Yep, that's why the modders use a capacitor+resistor setup to create what's called a "lowpass filter" that effectively transforms the square wave PWM signal into a continuous DC signal that's harmless for that type of fan. If you do exactly what Rob Duthie did, it'll be okay.
I don't think you should take the datasheet advice literally (that the fan speed can't be adjusted). That fan is just a DC brushless motor, and I fail to see how driving it with a variable DC voltage to control its speed would harm it as long as its nominal voltage isn't exceeded. I might be mistaken here though (for example, that fan would be a stepper motor, which would require some complicated electronics driver card, but I'm yet to see a fan like that).
Hi
Well the Jamicon fan is a very similar fan design so will have the same issue as it has a bushless design as well, The noise it makes suggest that can't be good for it either. At least the Sunon has better data sheets than the jamicon fan.
Well to date the sunon works a treat and is way quiter.
All Victron has to is change the PWM rate and all will be well.?
Regards
Rob D
NZ
ecoman avatar image ecoman Rob Duthie commented ·
Thanks for quick responses folks, I share your views on filtered DC being certainly being more gentle on the fan than Victron design bare PWM square wave at 25Hz making the fan cry out loud. Adding a capacitor will result in higher average voltage and thus higher fan speed (just more cooling than designed :o) ). Reading your text (Rob), you mention only the capacitor across terminals, no resistor. Is that how you ended up setting it, or did you actually add the resistor also (not shown in pics). A resistor could be used to keep the fan speed the same as without RC circuit, yet top revs would be lower compared to original setup when PWM at 100% - so I guess your setup is just fine. I'm just curious on whether you used a resistor or not, and how do you see pros and cons of it?
Thanks.
Rob Duthie avatar image Rob Duthie ecoman commented ·
Hi
Not used a resistor as it did not make much of a difference, but only used a 47uF value cap only a made a slight increase in speed, but very much quiter overall. compared to before. The rubber mounting improved it much better again.
Regards
Rob D
NZ
sharpener avatar image
sharpener answered ·
Perhaps it would be good to add a series resistor anyway as @popnic suggests, so that the source of the PWM waveform (whatever it is) doesn't drive directly into a capacitive load. Depending on the source impedance, that could result in very high peak currents which would not be good for either the driving circuitry or indeed the capacitor. Like @RayMiller I too was surprised by the very "agricultural" fan noise from my new MP II, for its size it is certainly the noisiest fan I have encountered in a long career in electronics.
ecoman avatar image
ecoman answered ·
Hi Rob, all, and thanks for sharing your implementation, I'll be doing the same mods once back at my remote facility. I will also take my oscilloscope with me to see the signal waveforms and mean voltages before and after changes and can post my findings here.
BTW, does anyone know if the noise originates from just one fan or both in the Multiplus II 10kW model? (would expect Victron to run both fans with the same low freq pwm, though...). Do the smaller models have two fans like the 10kW one, or just one?
Looking at the fan specs, it shows 24V, 207mA, which works out to be the 5W. Thinking of the serial resistor and the impact of it on the power the fan receives, I did a rough math below. This is lacking the effect of the capacitor boosting the speed, and the current value is an estimation, so not exactly accurate but should provide some clues on how the serial resistor size impacts on fan output.
Voltage resistor resistor pwr max fan voltage fan current fan power % of nominal
24,0 V 0 ohm 0,0 W 24,0 V 0,207 A 5,0 W 100 %
24,0 V 5 ohm 0,2 W 23,0 V 0,198 A 4,6 W 92 %
24,0 V 10 ohm 0,4 W 22,1 V 0,191 A 4,2 W 85 %
24,0 V 15 ohm 0,5 W 21,3 V 0,183 A 3,9 W 78 %
24,0 V 20 ohm 0,6 W 20,5 V 0,177 A 3,6 W 73 %
24,0 V 25 ohm 0,7 W 19,7 V 0,170 A 3,4 W 68 %
24,0 V 30 ohm 0,8 W 19,1 V 0,164 A 3,1 W 63 %
24,0 V 35 ohm 0,9 W 18,4 V 0,159 A 2,9 W 59 %
Ie, it would seem that already a 33 ohm resistor would cause the fan to receive only ~18V instead of 24V, and reduced current, resulting in about 60% of the fan power compared to what the factory setup with 100% duty cycle 24V feed would provide. While the fan spec doesn't tell how much less airflow that would mean, I'd guess it is going to be significantly less, probably in direct correlation with fan power and that would discourage using resistor values that high.
As such, it would seem that the implementation by Rob with no resistor is the safe one from maintaining the same (in fact, better) airflow, although a small resistor (say up to 10 ohms) should not cause too dramatic power drop, especially considering the boost from the capacitor which might compensate enough to keep the fan power and thus airflow close to factory spec.
Also, if using only 10 ohms resistor, a 1W model would be fine, as the power dissipation on the resistor would never exceed 0.4W. The 1W rating would actually be ok all the way to 30+ ohms. Then, is there a value of using such a small resistor even to protect the driver circuitry from the change in load impedance...?
Thoughts?
Hi
The resistor will get hot and over time this will fail as i have seen in the past with other fan circuits. The capacitor by itself is simple and effective and no heat is generated.
I will be fitting another fan to a clients Multiplus2 unit which i am installing in case they complain about the noise, i will check the impeadance of the output fan ciruit to see what i can measure etc.
Regards
Rob D
NZ
ecoman avatar image
ecoman answered ·
The new SUNON EEC0252B1-000U-A99 fans arrived, but no rubber mounts included, so need to find or create ones. Tested at home without PWM, just straight 24V corresponding to 100% pwm signal, with and without 10 ohm/3W serial resistor.
Without serial resistor and free airflow I get 24V and 192mA = 4.61W power consumption (100%). With airflow obstructed (fan against the table), current increases to 215mA and power to 5.2W
With serial resistor current drops to 170mA, power draw to 4.08W (89%); voltage over the fan to 22.1V, thus 3.76W for fan (82%), and 0.32W (7%) for resistor, which warms a bit but hardly noticeable with finger. With multimeter temperature probe I get a reading of 40C, correlating with finger reading. Based on above numbers, the actual resistor value is 11.2 ohms.
With obstructed airflow current increases to 190mA, power draw to 4.56W (99%) of which fan gets 4.16W (90%) and resistor 0.40W (9%). Resistor temp now 43C. The resistor was in standstill air, not in fan airflow. In MP2 the resistor would inevitably get some airflow, yet it is a warmer environment than +23C now. Tested also with the second fan, got the same readings - so these fans seem to be identical twins. (I ordered two fans as MP2 has two and I don't know if it is one or the other or both making noise - assuming worst case).
Based on quick testing I figure I could use a small serial resistor, lifetime should not be an issue due to minimal temperature rise. Will see if the resistor makes any difference in results, will decide once I get to try the alternatives. Surely without a serial resistor the circuit is most reliable as only one component to fail and no chance of cutting the circuit like failed resistor can cause; yet both have the same chance for shorted capacitor which can also happen.
I used these rubber mounts from RS Comp # 126-3939 they come in a pack of 8
and put a pice of foam on the bracket as per my thread photos.
Regards
Rob D
NZ
Thanks, the same seem to be available here also, will get those rather than re-inventing the wheel.
ecoman avatar image
ecoman answered ·
An update, things seem different with the 10kW model of MP2 - and so far I have not succeeded in making the device quieter. First, the fans are different, and there are two of them. Second, the capacitor makes no difference on the noise the MP2 generates, I tried 47, 100, 220 and 330uF capacitors parallel to both fans with only marginal impact on noise.
Ths lower power fan is JF1238B2HR-R, 24V 0.32A = 7.7W fan, and the higher powered one is JF1238B2TR-R, 24V 0.60A = 14.4W fan, both JAMICON as in other models. However, the 5W fans I bought based on the information from smaller systems would not most likely not be adequate replacements, and would not be able to generate the same airflow and cooling.
On the signal waveforms, I didn't capture them at all power levels, but here some samples when the inverter was under a modest, bit over 2kW load. The first one is without any capacitors connected, standard Victron factory setup and showing just one of the fans voltage. To be noted that both fans were driven with exactly same kind of voltage and frequency PWM signal
The second oscilloscope screenshot shows the voltage of both, each with 47uF capacitor connected...
...and the last one with 330uF capacitor on fan power feed:
As you would expect with the largest capacitor, the peaks smoothen and the lowest voltage is no longer zero but a slope towards zero volts, until the next peak comes in. BTW, the scales in the oscilloscope were 5V vertical (in single graph displays, 10V in two channel displays) and 20ms horizontal division. As you can see, we get about 5 full phases in 8 intervals on the screen - ie. 8x20ms = 160ms for 5 pulses, which makes about 32 ms pulse interval, or about 31Hz frequency. I don't know yet if the PWM frequency changes along with the load, but at least in this case it seems to be slightly different than the 25Hz mentioned earlier, but maybe the same control circuitry with "approximately" 25Hz...
Just for the sake of it, here few more samples of the same signal with slightly different load - as you can see, there are varying number of peaks on top of the pulse, not clear if intended or just a by-product of the fan control circuit. Whatever the case, those seem to be 4 peaks in approx 13..14ms, or ~3.5ms per phase, or about 300Hz frequency. That's another nasty frequency to listen.
The next thing I'll try is to disconnect the Victron fan control completely, and drive the fans with plain DC power from a lab power supply to see if a plain DC voltage on the fan (mounted in the frame as is) would generate noise, and if so, which level. That should establish the reference which can be achieved with Victron standard fans. If still noisy, should see if a quieter fans could be found. If clearly less noise, then I'm thinking that it should be possible to convert this PWM to plain DC (0-100%) analog voltage. There are converters which change PWM to 0-100% voltage level, but the ones I've seen so far are all either 0-5V or 0-10V output, have not found any with 0-24V output. Yet it should be possible to convert to that range with a simple circuit.
Thoughts from your experiments and findings, and what do you think about changing PWM to just DC level 0-100%?
5 comments
By just putting in the rubber mounts and changing out to the fan to a Sunon fan the reasonants goes away much quiter inverter allround i have being running this for about 4 months now with no issues and piece of mind. And just a 47uF 63v cap across the motor wires. just try this nothing to loose, dont get to hung up on the PWM issues this won't go away until Victron acknowledge the have a poor PWM control for there fan cooling very simple.
Sunon EEC0252B1-0000-A99
and put a piece of foam on the bracket as per my thread photos.
Yes, I've got the same rubber mounts in my hands right now, the problem is that for the MP2 10kW model they cannot be changed without unmounting the whole unit and undoing the screws in the backside of the unit. Given the weight of 50kg and tight space, it is no easy feat to get it off the wall, but doable if must. The other problem is that the new 5W fans I have are only 1/3rd of the power of the original and cannot push as much air against the counter pressure, so even if changing the fans I need to find ones which can keep up the same airflow in the same chassis. I now have a DC power supply on site, so I can check if plain DC feed will run the fans quietly.
raymiller avatar image raymiller Rob Duthie commented ·
Thanks for all your work Rob, I was slow to move, looks like the fans are in hot demand and not in stock in most places I have access to in Australia, RS supply is August and Mouser 2023.
I also note the Sunon fan bearing is magnetic offering lower vibration transmission, ideal for Victron Inverters.
All we need now is to be able to change the fan by just removing the top cover, as opposed to disconnecting the inverter and lowing 10's kg all the wall.
Hi Ray
The fans are avaible In NZ from my supplier they are in stock. HiQ Electronics.
I have done a couple now for my clients to keep them happy.
Yes i prepare them before installing them, yes you have to remove the mount to mount the new fans on to,only done the 5Kw models to date.
You could do from the top just need a right angle screw driver to remove the old fan.
Does the 10 kW model use the same Jaimcon fan?
Regards
Rob D
NZ
While the fans in the 10kW MP2 are also Jamicon, unfortunately they are not the same 5W fans as in smaller MP2 models. The fans in the 10kW model are much more power hungry, 7.2W and 14.4W according to the specs posted earlier (although the math gives 24x0.32A=7.7W instead of spec'd 7.2W). Below the model numbers
ecoman avatar image
ecoman answered ·
Googling for the specs of those fans, this is what I found:
Which says the bigger fan alone produces almost 53dB at full speed, while the other is about 10dB quieter.
5 comments
Wow, a 4000rpm fan is going to make a *lot* of noise in the MP II 48/10000 -- and presumably the Quattro II 48/10000 when it emerges. Which is a pity, because that's what I was intending to use... :-(
Does anyone know what the fans in the original Quattro 48/10000 are -- are they quieter?
Ecoman, how did you find out which fans the MP II 10kVa uses?
ecoman avatar image ecoman iand commented ·
Simply by opening the box and looking :o). Ie, I bought the MP2 10kW model without any clue about the loud noise it makes, only to discover it once installed. My previous inverter (Studer HPC 4.4kW) was silent, and it never crossed my mind an inverter with 2x the output would make such loud noise.
Here the pictures from inside the MP2 10kW model, you can see the lower rated fan on the bottom left side, and the more powerful one further up on the right side of the unit. On the top there is a massive toroid transformer which makes up most of the unit weight (49kg).
Photos of the fans below. Those cannot be replaced without taking the unit off the wall, as it seems the mounting brackets are screwed through the back panel. Will update if I find another way to do it or find a way to otherwise dampen the sound a bit. For now, I have only the 5W fans I thought could be used, but apparently not.
Top fan:img-20220611-165211.jpg
Bottom fan:
iand avatar image iand ecoman commented ·
Looks like the high-speed (4000rpm 0.6A) fan is cooling the heatsink (by pulling air through it) for the power MOSFETs which is behind the PCB in the bottom right corner, which is where most of the heat dissipation will be. What's annoying is that Victron could easily have used a slower-speed 140mm x 25mm fan (like the Noctua industrial one) which would have been a lot quieter and given more airflow... :-(
The low-speed (2800rpm 0.3A) fan is just generally blowing cool air up through the case and across the transformer.
I don't suppose anyone with an original Multiplus/Quattro 48/10000 has done the same thing and looked inside? ;-)
Hello ECOMAN,
and now where are you with your improvements?
ecoman avatar image ecoman maa commented ·
Sorry for long silence, have not been here since last post, given the apparent dead-end I ran into. What I did after the initial tests documented above, I used a lab DC power supply to feed both fans at 24V, which showed 0.79 amps current drawn, approx 19W instead of spec'd power of 14,4W+7,2W=21.6W, but close enough to hear the result. To my disappointment, the noise remained at very high level anyway - which is expected given the fan spec says 52.9dB for the bigger one. Thus I concluded that there's no way to silence the fans even if driving at higher frequency, as flat DC couldn't do it.
It also seems that there are no 120mm fans which could maintain the same airflow and static pressure without much less noise. The best Noctua 2000rpm fan gets to 44% airflow with 29.7dB, and the 3000rpm fan to 67% @43.5dB.
A bigger 140mm fan would be quieter for the same airflow, Noctua has one which is 97.2% of the original fan airflow at 41.3dB - that is almost 12dB less - but I doubt it would be possible to make it fit without major modifications inside the box, like moving the pcb on the right side couple of centimeters further up... and even if done so, would the increased area for airflow be constrained by the cages/components below it, could well be - but cannot check it anytime soon.
Note that I am with 10kW MP2, not the 5kW unit - so it must have even higher cooling requirement and the thing weighs 50kg, not so easy to get off the wall for mods. Reading about using less than half airflow fans because the unit is at <25C temperature, and to hear about dealer changing those for their customers seems risky at best but certainly an option when the ambient temp remains low enough.
Granted, my unit does not run at full power for extended periods, but it does run at over half power for long periods - for example when charging two hybrid cars at low power (2..3kW each), or one car with built-in 7.4kW charger while the rest of the house consumes as usual. At those times I want to be sure MP2 doesn't get damaged with overtemp. I don't have information on how good the output derating is, and whether it would be enough to save the inverter when under, say hours of 6..8kW load with ambient temperature slightly over 30C.
Ie, so far I am without a solution to silence the beast, but would definitely like to find one, even if it would require a serious mod to the inverter.
maa avatar image
maa answered ·
Hello dear Victroniens and Victronniennes,
Concerning the subject of fan noise, I suggest you make an online petition on this forum in order to accumulate the greatest number of VICTRON customers.
So we could ask VICTRON R&D to include at least in the future version of the Multi-II Firmware the fact that the fans are only triggered according to the internal temperature of the device and more on a mix.
If you agree, here is the link to this petition:
https://community.victronenergy.com/questions/157987/petition-bruit-ventilo-multi-ii-noise-fan-on-multi.html
Victronement your
@Maa I periodically read the Firmware Changelog published on the Victron Professional website.
Firmware xxxx496, released April 19, 2022, contains a clear indication that the fan is also started proactively based on actual current, not just temperature:
Minor improvement on fan driver.
(Under certain specific conditions the fan did not start even if the average current indicated that it should. This is a minor improvement since it did not impose a real problem because the fan could still start based on internal temperature sensor.)
Personally, I think this is good, but the only problem is that the MultiPlus II factory-default fans are noisy.
maa avatar image maa mondeoman commented ·
Thanks Mondeoman for this information. I pushed it on the French Forum.
It seems this is a serious problem for many domestic users (myself included, I have had to soundproof the door of my kitchen because of it). So it is regrettable that Thierry Cortassa (Victron Energy Staff) has closed the Petition topic rather than taking the request for action seriously.
As noted above by many contributors to the discussion, there are various technical solutions which could easily be adopted to solve or at least improve the noise problem if Victron had a mind to do it.
rvicev avatar image
rvicev answered ·
Thanks to all the efforts by contributors above and in other threads on the Victron Community platform and elsewhere, we now know that the fans start based on :
a) ambient temperature of ca 30-35C
b) power drawn (actual current)
However, there seems to be one aspect missing in above discussions.
According to Victron specs the MultiPlus will work in ambient temperatures of -40C to +65C, with derating at higher temperatures, of course. Very impressive !
I´d say that at 65C in a residential environment you won´t be bothered by the noise of the MP II, because you have very serious other problems. Still, it is very impressive because at 65C the air blown through the MPII has very little cooling capacity. That means a lot of air has to be blown through the MPII, requiring a very powerful fan.
Common sense therefore says that if you are sure that the temperature where you will be installing the MPII will never be higher than e.g. 25C, you do not need such a powerful fan .....
No surprise therefore when I came across this link https://www.photovoltaikforum.com/thread/158718-lautst%C3%A4rke-multiplus-ii-48-5000-70-l%C3%BCfter-brummen/?pageNo=1 (in German) where German reseller Panda-Solar states that they have been installing the 2000 rpm version of the Noctua fan for clients, who have them running without any problems for more than 2 years. Difference being that the 2000 rpm Noctua has a noise level of 29.7 dB, whereas the 3000 rpm produces 43.5 dB .........
The difference between a whisper and an older model dish washer.
I love the sound of silence.-
6 comments
sharpener avatar image sharpener commented ·
But the objectionable nature of the noise arises from the way it is driven, by a relatively low-frequency PWM variable-speed signal with no smoothing.
A fixed speed fan would be much less annoying, even it the measured noise level was the same.
So if you are going to modify the inverter and so invalidate the warranty then IMHO it would be better to fix this aspect of the problem first. Unlike Panda-Solar's approach, the mods described by @Rob Duthie and others do this with at most a trivial reduction in maximum flow rate so the noise is reduced but the thermal management of the inverter is virtually unimpaired.
Rob Duthie avatar image Rob Duthie sharpener commented ·
Hi Sharpener
Good call, is Victron is listning? NO?
Regards
RobD
NZ
rvicev avatar image rvicev sharpener commented ·
I fully agree that you should get rid of the noise caused by the low freq PWM variable speed drive in combination with the fan provided as standard, i.e. better quality fan, mounted with little rubber silent blocs and capacitor.
I merely suggested that you can go even further under specific conditions. Note that I did mention : a) residential, b) temperature never above 25C. I can´t see how you would impair the thermal management by getting rid of excess fan capacity you simply don´t need. The dB scale being logarithmic, there is a huge difference between 29.7 dB and 43.5 dB
Rob Duthie avatar image Rob Duthie rvicev commented ·
Hi
Yes i added rubber mounting isolators as per mod notes.
sharpener avatar image sharpener rvicev commented ·
The software will not know it is a smaller fan. So at all fan settings there is a risk that the fan will only deliver 2/3 of the air flow the s/w is expecting. Even if there is closed-loop control and additional protection e.g. backstop overtemp sensors this will give higher internal temps and hence reduced life/reliability, even in a domestic setting. (My first big project involving heat sink design was over 40 years ago and I am still learning.)
Under some circumstances the 5kVA unit installed in a cool room on the N side of my house still emits exhaust air at I am guessing 50C so I would not want to do this.
My wife's solution is to isolate the inside of the glass panelled door to the kitchen by putting old towels in contact with the glass to stop it vibrating in sympathy and to absorb incident sound. This has the merit of not requiring me to disconnect the 30kg Multi and take it off the wall to get at the fan mounts which AIUI are on the rear of the unit.
Software doesn´t know anything about fan capacity at all, whether it be bigger or smaller.
All the software sees is a temperature, if I understood correctly from this and other forums the measurement is done via a LM35 (accuracy in theory +/- 2C, in practice at best +/- 3C, so fairly inaccurate). If temperature passes a low threshold the software will start the fan at a certain low speed and if temperature continues to increase, it will simply ramp up the fan speed.
The only thing that matters is if, once it arrives at 100% fan speed, that is still sufficient in case you put in a lower capacity fan. Normally that would be guesswork, and I had say : no, don´t do it.
However, under the specific conditions I stipulated – residential & T always less than 25C – the experience of German reseller Panda-Solar has sufficiently proven to me that the lower speed Noctua industrial fan (or similar) is sufficient.
Yes, you have to take the Multi of the wall to make any of the suggested mods in this thread and yes, unfortunately that thing weighs 30 kgs (but mind you, It can be a lot worse e.g. a comparable Outback Radian weighs ´only´ 40 – 60 kg, so be happy that you choose Victron .... )
mathieu-van-den-berghe avatar image
mathieu-van-den-berghe answered ·
to add upon the others.
MPII 48/5000
when not charging/inverting : loud humming noise
when above 2kw : fan kicks in and noise is annoying : goes through all the walls, neighbour complaints, discussion with wife, sleepless nights etc
modified the MPII with resistor/capacitor as stated above. Makes it a lot better, but still ...
to comment on the airflow : by adding the resistor, the maximum airflow is less. I use the inverter for hours at max power. I see that with ambient temperature of 20 degrees, it gradually decreaes its output power to around 4400W instead of 5000W, this happens after 10 minutes or so. probably because it's running to hot. so for many situations, adding a more silent fan, that switches 100% on from the moment a PWM signal is seen, should be good, unless you need the full 5000 W for prolonged periods.
personally cannot believe that someone can have this unit in a boat/RV.
1234enough avatar image 1234enough commented ·
I have multiplus ii gx 48v 5000va and agree it is noisey, haven't tried any modification as yet, what did surprise me when I took the cover off was how poorly air sealed the fan was to the case /from one side to the other side of the fan with gaps around the fan case, this must cause quite a bit of re-circulation of air, in turn causing the fan to be less efficient than it could be.
Charlie avatar image
Charlie answered ·
to the experts here, anyone knows is the noise situation is the same with the Quattro's? will I have twice the noise in parallel configuration? thx u
raymiller answered ·
Bobby the fan noise as you state is excessive, the fundamental problem seems to be the fan model being used. The centre cover ( which is large for a fan) of the fan electronics resonates easily which is causing an unusually extra sound emanating from the fan bearings, made worse by any PWM speed control.
I've successfully replaced my fan (as per Rob in NZ) with one, half the thickness and used fan mount isolation rubber mounts as suggested. The PWM of the replacement fan does not seem to make any extra noise.
I did at the same time add a dense stick-on noise-reducing material to the inside of the front panel which also helped reduce the MulitPlus case resonances. The final result is white noise from the inverter when under load, no more noise than what one would expect from normal fans and similar to Fronius inverters, and much less annoying.
Unfortunately to replace the fan requires removing the inverter fully to access the rear screws holding the fan mount bracket, although Rob seems to think it can be accessed from the rear on-site, I found it still much easier to have the unit on the workbench.
It's a simple mod but one which would not be necessary if a different model fan was used.
nickdb avatar image nickdb ♦ commented ·
It has already been stated on other topics, but most of the models made from middle, or so, of this year have a different fan setup and they are nice and quiet (ish). It is a huge improvement.
I have put them side by side for comparison.
It is pretty close to the mod mentioned on this thread.
michaelvh avatar image michaelvh nickdb ♦ commented ·
That is great news @nickdb. Out of curiousity, did you by any chance have a look inside already to see how it differs from previous models? Different fan model or mounts, or just different fan control?
nickdb avatar image nickdb ♦ michaelvh commented ·
Not yet, but I do intend to.
