buzzlightyear avatar image
buzzlightyear asked
Multiplus 24/1200 Programmable relay state
The programmable relay contacts are marked COM, NC and NO. My understanding of the relay's default behaviour and normally open is that there should be continuity between COM and NC during normal (No alarm) operation, and continuity between COM and NO if there is an alarm. I tested the continuity today, and found that there is continuity between COM and NO, and no continuity between COM and NC. This is unexpected, is my understanding of the default behaviour of the relay incorrect?
The relay's behaviour has not been changed via VE Configure, in fact I have not even downloaded it yet.
Product ID: 2667
Firmware version: 469
VenusOS Remote console shows no alarms, all show Ok under Alarm Status
Would appreciate any help.
Relay
That is the default behavior.
Important for this behavior is the "Invert virtual switch usage"
buzzlightyear avatar image buzzlightyear commented ·
Thank you very much for the detailed and exact answer, much appreciated! I think I'll download VE Configure just to get visibility of all the settings.
Daniël Boekel (Victron Energy Staff) avatar image Daniël Boekel (Victron Energy Staff) ♦♦ buzzlightyear commented ·
@buzzlightyear
To add to M.Lange's answer:
-this is done so when the unit is not powered / off, the alarm relay is 'active' and you know the unit is not in 'normal' state. Otherwise you couldn't know from the relay state if the unit is functioning normally, or 'off'
