reginald-gerard avatar image
reginald-gerard asked
MultiPlus-II 48/5000/70 safe to apply 220VAC on the output side when turned off?
Using this in a fixed caravan, shore line is only 4 Amps and my wife wants to use her Senseo Coffee machine (2,700W max.)
Issue is: when the MP-2 is turned off, there is no power in the caravan. Would have been a nice option to be able to switch to bypass the MP and supply the 4 Amps to the caravan when off.
So my actual question is: If I wire the MP after a whip switch that either supplies shore power to the MP or the Caravan directly, will the 220VAC that is then on the output side of the turned off MP-2 cause any problems?
btw. not a lot of options to choose from in the Topics list.
battery charging
Hi @Reginald Gerard
Not safe!
Do -not- apply grid to the output of the inverter, this -will- damage it and it is not covered by warranty.
Do it like that and you'll be safe:
reginald-gerard answered ·
m.Lange Thank you for that. I should have been able to come up with that, maybe getting old and set im my ways. Will apply that suggestion. Daniël, good to know, just wanted to be sure.
I would recommend you to always switch L and N not only L.
