Simon Jenje avatar image
Simon Jenje asked
Can a USB - HDMI adaptor be used to connect Touch 50 to a Venus GX
I am inquiring if the Vieus GX can be connected to the Touch 50 panel via a USB - HDMI adapter cable with the USB power cable from the Touch 50 then being plugged into the second USB port.
The other option is can we connect a tablet to the Venus GX via USB to USB 3 cable to display the Remote console on the tablet.
Venus GX - VGX
Matthias Lange - DE answered ยท
I don't think so.
1. the USB ports at the Venus GX are just simple USB 2.0
2. you need a driver for such an adapter and this driver is not implemented in Venus OS
But you can simply connect a tablet to the Venus' own WiFi and use 172.24.24.1 or venus.local to connect to the remote console with you browser.
Simon Jenje avatar image Simon Jenje commented ยท
Thanks for that. The tablet option is the way I was designing the system but I just wanted to see if we could connect directly.
0 Likes 0 ยท
