galileo avatar image
galileo asked
Skylla-IP44 Battery Charger 12/60(1+1)
On the Victron Energy Skylla-IP44 Battery Charger 12/60(1+1) 120-240V with the 60 Amp Output I assume that this is controllable with the Remote Panel and that the Seven (7) Stage Charge Profile will be followed.
On the second Output of 3 Amps for a Starting Battery will a similar multi-stage Charge Profile also be followed? Or, will that output be continuously at 3 Amps? Does it ever shut this output off when Starting Battery is fully charged?
Skylla
