All of the tutorials I have read mention an option to select lithium as the battery type. I am not seeing this in my options. Am I doing something wrong?
I also chose my settings based on other tutorials, so feel free to tell me if they look bad :)
Hi Pizzajohn, See attached for my MPPT (also a SmartSolar). You have got 'User Defined' showing which to me indicates that you have altered a 'pre-set' (such as Lithium). This is OK however if you want 'standard' preset as defined by Victron pull down the 'User Defined' until you see your battery type and then select. After that you can alter some parameters as you desire and you will be confident that you have started from the LiFePO4 baseline. Once you change any parameter my settings also change to 'User Defined'. Best of luck.
15 People are following this question.
