thetree avatar image
thetree asked
Blue Smart IP22 and 20AH Lithium Battery
Hi
I have the 3 output version of this charger and I have a couple of questions;
1) I would assume it's OK to charge the 20AH battery which has a max charging rate of 10amps, since the battery will limit the current it will absorb.
2) I also have a 200AH lithium which is hooked up to the charger and I am wondering if it would be ok to hook both batteries up at the same time.
I understand that the charger has one algorithm but that the outputs are FET isolated so both batteries at once should be OK
Can please someone confirm this for me?
Thanks,
Steve
charger
thetree answered ·
I discovered that this is not possible
