Hello. I have the Phoenix Multi plus 12/2000/100 and wondering if I can buy and connect a dongle for Bluetooth functionality? If so, which one?
Thanks and best regards,
Jon Arne Nilsen
It seems to be an very old unit, so I think it is not compatible with the VE.Bus Smart dongle.
https://www.victronenergy.com/live/vebus_smart_dongle_manual
You have to check what firmware is installed and what is the latest available firmware.
Take off the upper front cover and there should be a chip with a sicker on it.
On this sticker should be a 7 digit number with .HEX at the end.
If this number starts with 19#####.HEX the unit is to old. If it starts with 26#####.HEX it is compatible but you would have to update the firmware.
12 People are following this question.
