leftishut avatar image
leftishut asked
Can I use the Venus GX to program and monitor a multiplus and a Phoenix?
I have a multiplus 24/3000 and a Phoenix 24/1200. I bought 2 Ve.buss dongles but now understand that was a waste of money. Apparently I can use one for the multiplus but it is very limited. So I would need to buy a Ve. Direct for the Phoenix and a program usb cable for the multiplus.
Could I return the bus dongles and just get the Venus GX to monitor and program both? Even if only one at a time? The cost is not much higher.
Venus GX - VGX
For the Phoenix you need a VE.direct BT dongle or USB cable.
For the MultiPlus you can use "remote VE.config" via the VRM portal to change the settings.
https://www.victronenergy.com/live/vrm_portal:remote-veconfigure
But if you want to update the firmware of the Multi you need a MK3.
