wahlet avatar image
wahlet asked
600V from micro hydro generator, to battery bank?
I plan to add a battery bank to an existing micro hydro system. I would like to parallel 3 of the Victron Quattro 10kVA 120V to take power from the 24kW capacity hydro generator (or a diesel backup generator) to charge the battery bank and feed through / invert to 120V AC for household power. The problem is that the hydro generator produces power at 600V AC whereas the Victron Quattro inverter-chargers will accept only between 90V and 140V AC input. I could put a 600V to 120V step-down transformer between the hydro generator and the Quattros but this would reduce efficiencies.
Is there a way to set up a Victron product to handle the 600V AC output of my hydro generator? Or else is there an inverter-charger on the market that can handle that input voltage directly?
MultiPlus Quattro Inverter Chargerbattery chargingHydro and Wind Power
mt-geek avatar image mt-geek commented ·
Is the generator 3 ph high Y or 1 ph. how many wire are coming out of the generator 12, 9, or 4
