While charging lithium batteries, using the lithium setting. What effect does the temperature compensation have?
I.e. reduce charge current belwo 5 degrees for example?
Matt
Matt
As far as I know (update: in tech specs it says temp. compensation only lead-acid batteries) there is no temperature compensation in Li-Ion mode.
Since there is no protection for low temperature charging, you must ensure not to charge below 5°C (or 0°C as mentioned in the manual...I think the new value is 5°C now).
12 People are following this question.
