tobias avatar image
tobias asked
Function from the Remoteport of the MPPT 150/60 .
What is the remote connection that is bridged at the factory used for?
Is it possible to stop and restart charging via the ve.bus bms with this input if the state of charge and the temperature of the battery allow it.
if this is possible, the battery protect between the battery and solar charger can be omitted.
Bluetooth
klim8skeptic avatar image
klim8skeptic answered ·
Hi Tobias,
You are correct, the remote port on the mppt can be used to disable charging.
A snip from the manual.
chris61 avatar image
chris61 answered ·
Can you use the internal relay to switch the remote from on to off, when power is applied to relay. If so how would you wire it. I have my bms set to to power up to 4 optocouplers to stop charging
