rjb1696 avatar image
rjb1696 asked
Utilizing mppt 100/50 with lg 60 ah lithium polymer batteries
I would like to use my victron solar charger for a lithium polymer battery chemistry for a storage application. While I am no expert it seems that the lithium polymer batteries have slightly higher charge voltages than the lifepo4 algorithm in my mppt charge controller. a) can i adjust this to suit the higher voltages, or b) should i just use the lifepo4 algorithm and accept slightly lower charge capacity? thanks, John
Lithium Battery
Murray van Graan avatar image
Murray van Graan answered ·
Hi @rjb1696. Using VictronConnect you can set up user defined charge values.
see here: https://www.victronenergy.com/live/victronconnect:start
