ryanb avatar image
ryanb asked
Generic BMS driver for Venus OS
I am investigating the development of a custom BMS, which would mainly be used with Victron systems.
a) Does the Venus OS have a generic driver for integration with third-party BMS devices?
b) Where is the best place to start researching more about custom BMS integration with the Venus OS.
Thank you
Venus GX - VGXBMS
Did you eventually find a way to do this?
fantail avatar image
fantail answered ·
get the dbus bridging examples here:
https://github.com/victronenergy/velib_python/find/master
create a python task to open a socket port
send data to your task
decode and use victron python lib functions to place values on dbus.
if you use the pre installed dbus battery settings then just full in the values.
note: you can add additional dbus registers if you want - but then you may have to start changing the web interfaces.
Victron python lib functions are heavy on CPU resources but should be OK for your needs
regards Fantail
Louis van der Walt avatar image
Louis van der Walt answered ·
