ianh40 avatar image
ianh40 asked
Multiplus 3000 will not turn off from Colour CCGX
I tried to turn off my Multiplus from my Colour CCGX remote and it did not work. It was business as usual for the inverter/charger. I had to go to the inverter and turn it off at the manual switch. Is there additional programming that I missed when setting up the CCGX and the Multiplus?
MultiPlus Quattro Inverter ChargerCCGX Color Control
nebulight avatar image
nebulight answered ยท
Are you using a VE.Bus BMS? If so, you currently can not control the state of the inverter with a ve.bus bms. You can control the incoming current, but can't control the on/off/charger only function. I've been told that may come in a future GX software release.
ianh40 avatar image
ianh40 answered ยท
Thanks Nebulight. I am using a Victron BMS712 with the CCGX. Thatโ€™s disappointing given that it is a basic, standard function on every competitorโ€™s remote. Surprised by this coming from Victron.
nebulight avatar image nebulight commented ยท
The bmv712 is not the BMS, thatโ€™s the battery monitor. Are you using Victron lithium batteries? If so you most likely have a ve.bus bms.
As for the limitation, the remote panel for the multiplus is technically isnโ€™t the ccgx itโ€™s the digital multi controller. With that said the ccgx can do most of the same things the dmc can do, but if you have a ve.bus BMS, that limitation is clearly stated in the manual. With that said, pretty sure that feature is coming soon.
0 Likes 0 ยท
