taajis avatar image
taajis asked
Blue smart IP65 / 12V - reaction to voltage drop
Does the charger (blue smart ip65 12v 10A or 15A react and start bulk charging if it detects that the voltage drops after charger has finished it’s charging sequence? For example, fully charged battery and you turn on auxiliary heating (eg Webasto). Does the charger see the drain and start automatically to supply power?
Moreover, my car’s CAN bus wakes up (and takes about 5-6A) when you start charging. Assumingly, the charger handles this, but is recond possible without detaching he battery from the car?
thanks!
battery charging
