willemoud avatar image
willemoud asked
2 Multiplus in parallel - failed shortly after powering on
The installer installed 2 multiplus in parallel (2x 5KWh), but 2 minutes after powerup, the 'master' inverter 'blew up'. I need to know if the installer has followed the correct methods. He is not experienced with Victron. Is there an expert I can show diagrams or an install manual I can refer to specifically for parallel connections ?
Multiplus-IIMultiPlus Quattro Inverter Charger
Just show us some pictures and/or a wiring diagram, here are many experts. :)
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
klim8skeptic avatar image
klim8skeptic answered ·
Wiring Unlimited has some useful information on parallel systems.
willemoud answered ·
Here are some wiring photos
1) 7 x Lithium Titinate (LTO), batteries in parallel
2) Master Victron on the right and slave on the left.
The Master (right one), burnt out after about 2 minutes from power-up. Batteries were almost full
3) SMA grid connected solar inverter with 5 solar panel strings coming in.
5 comments
Do you have pictures of the wiring inside the inverters?
willemoud avatar image willemoud Daniël Boekel (Victron Energy Staff) ♦♦ commented ·
not yet, but I will try to get them.
Thanks for trying to help me out :)
If you notice the wiring coming from the batteries into the control box, you can assume the wiring lengths are NOT the same.
Is that a possible cause for the Victron inverter burning out, especially considering there are only 2 inverters in parallel ?
I now have 2 photos, but maybe they don't have the detail you are after ??
Hi
4 comments · Share · Accept
Hi Daniël could you please take a look at my photos and let me know if it's informative enough ?
Do you need to see the channeling ?
Hi @willemoud
Please have the installer fix your system, and when they are in need of help they know how to contact Victron sales for support.
podilamaya avatar image
podilamaya answered ·
@willemoud
Did you found what made the multi plus blow up?
Yes, unfortunately the installer of the 2 multiplus in parallel (2x 5KWh) did not program the system correctly.
