col-a avatar image
col-a asked
Blue smart IP22 12|30 recondition problem
I'm trying to recondition my 2x Trojan t105's that are one year old and in I would say fairly good order, but as per Trojans advice, the specific gravity of a couple of the cells are slightly low, so this needs to be done.
Charger with largest firmware, no loads on battery.
Basically the charger (set on high) gets to end of absorbsion around 14.84 to 14.97 depending on temperature, sits there with the current cycling 0>0.7>1.7>2.5>3.5>4.5 then back down to 0 over a couple of seconds. Then when it finally decides to go into recondition it will again cycle the amps quite quickly between 1.6 and 5.2 amps (mostly between 2 and 3amps) and never reach more than 15.28v then go to float.
This is all read from the app via Bluetooth.
Is this a problem with the charger or batteries?
battery charging
