Lucia avatar image
Does the Color Control support Outback Flexmax charge controllers?
Hi everyone
I'd like to know if the color control has any compatibility problems with charge controllers of other brands, such as Flexmax controllers.
Thank you all ! :)
CCGX Color Controlmonitoring
JohnC avatar image
Hi @Lucia
Outback kit has it's own specialty/proprietary comms needs. I've an FM80 in the spares bin at home, and hope I never have to use it again.
4 comments Share
Thank you so much for your answer John.
And do you know if I would have any problems with Sonnenschain batteries? I have a Victron Multiplus compact in the system, would it be enough?
This is really another question. Are the Sonnens Pb or Li for example? If Li with a bms, then you'd have to ask them. They weren't included in the Victron Li compatibility program, which was curtailed due to all the new arrivals (pretenders?) taking up too much testing time to get 'approved'. Not to say they wouldn't work with Victron kit, but they should know that.
And your FM may be ok too, just that it can't talk to the GX. In that scenario, a BMV monitor might be a worthwhile investment..
They are solar gel batteries: GEL Batery A602/850Solar - 6OPzV720
They are already connected to a victron multiplus, so maybe the information of the batteries can come from the inverter, as can be done with the VEConfig. Do you think there will be any problem?
I'll also buy a BlueSolar, so more info of the system (specially the batteries) will be available.
Nice batts. And sure you can get V batt and ac usage info from the Multi, but not SOC or solar input, cos it can't see the mppt.
If you're still considering whether to actually buy a GX (of several varieties), I'd recommend you do. The VRM portal is a stunner, and you'll soon work out what more data you can't do without.
A BMV monitor would be good, especially if you retain the FM mppt.
