Simple question, scenario as follows:
Use AC Out 2 relay, set off, when SOC lower then 90%
Use AC Out 2 relay, set relay on, when any AC available.
How can I program to ignore rule "set off" when any AC is available?
Hi @Captain
easiest way: use this:
https://www.victronenergy.com/live/assistants:ignore_ac_input_using_the_generator_assistant
11 People are following this question.
