john2019 avatar image
john2019 asked
CCGX with other brand BMS
Hi, All
I have 2 LFP batteries connected to victron easy solar all in one. The battery has its own BMS but not in victron LFP lists. Battery BMS only has 485/232 port and does not have Can port. Just wonder how can CCGX communicate with BMS and using BMS parameter to control battery charging and discharge, genset remote start.......... Many thanks
BMSCCGX Color Control
If you tell us what brand the batteries are from, maybe someone can help you.
4 comments
john2019 avatar image john2019 commented ·
Thanks. The battery is from EVE China and has not been tested with victron device, Just wonder how it can talk with CCGX through modification or sth..... I do not think someone used that battery before. So just image a nobody BMS has 485/232 port and would like to CCGX.
mihair avatar image mihair john2019 commented ·
If you know what parameters are published on serial port maybe an arduino with CAN HAT can translate what is needed to CCGX in order to integrate.
john2019 avatar image john2019 mihair commented ·
Hi, MihaiR I am not quite familiar with arduino device. Do you know what chips should I buy and what parameters should I know on the serial port? Many thanks
Matthias Lange - DE avatar image Matthias Lange - DE ♦ john2019 commented ·
I think for this you should have a look at the modification area.
https://community.victronenergy.com/spaces/31/index.html
