solarone avatar image
solarone asked
Temperature sensor Venus gx
Hi
Can the cable length for the temperature sensor of the Venus gx be extended,if so would it affect the readings of the Senor
Thanks
Venus GX - VGX
wkirby avatar image
wkirby answered ·
You can extend the cable. If you use the same gauge cable then you can probably go 10 metres without any issues.
