alby868 avatar image
alby868 asked
Kirloskar Generator not connecting
I have a 5KVA KOEL genset which is connected to a 5KVA multiplus 2 inverter/charger for a 15 kWh lithium battery bank. When I tried to start the generator & load the inverter, it is not connecting as I expected. From the sound of the generator,I found it is overloading a bit & relay in the inverter/charger gets disconnected.
So what can be done to solve this issue.
Any thoughts?
battery chargingGenerator
JohnC avatar image
JohnC answered ยท
Hi @alby868
Your Multi is certainly capable of overloading your genny, and so likely are your batts. You'll need to set a current limit within the Multi, and you can tune that to where your genny is 'comfortable'
In case the genny is actually being rejected, see here: https://www.victronenergy.com/live/multiplus_faq
The pages of the VE.Config in that article may show the current limit setting too. Hoping you have the kit to do this..
alby868 answered ยท
We have tried the current limiting also but still the relay gets disconnected in Multiplus 2. Is there any option to provide delay manually to relay inside the inverter/charger
JohnC avatar image JohnC โ™ฆ commented ยท
Might be possible with an 'Assistant' installed in the Multi, but outta my field. Maybe someone else can help there..
For a 'soft start' you could try enabling 'Dynamic current limiter'.
Some people confuse batt A with ac A when setting input limit, just a possibility.
Sometimes also helps to ensure it's not the genny baulking, these things can happen fast. A monitor light direct off the genny could show that.
Else it's back to that link I posted. I need to tick 'Weak ac input' on my own system for it to accept my genny. So you wouldn't be alone..
0 Likes 0 ยท
MultiPlus Generator FAQ
GX - Generator auto start/stop
Automatic Generator start/stop
 Hybrid Generators
Virtual switch - Generator start/stop
