chicchis435 avatar image
chicchis435 asked
Old Phoenix MultiPlus (VE Configure 1) LiFePO4 settings/compatible?
I have a Victron Phoenix Multi 12/2500/120 which is about 15 years old.
The firmware number is 1700123.
My understanding is it does not have a VE.Bus, however it can still be configured using the original VEConfigure, (but is not compatible to VEConfigure 2 or 3, and the firmware cannot be updated). Is this right?
Do I need a MK2 to USB and RJ45 cable to use VEConfigure with this unit?
Does VEConfigure allow me to change any settings which I otherwise can't change using the dip switches?
I want to use the charger for a LiFePO4 bank, can someone tell me what settings I can change using VEConfigure 1? Will I have enough control to adapt this charger for a LiFePO4 bank?
I'm also interested in what settings others using victron chargers for LiFePO4 batteries recommend.
Lithium Batteryfirmware update
akl avatar image
akl answered ·
Hello did you find a solution?
I have the same issue?
Best Regards Andreas
