I read your brochures that you can connect Orion-Tr chargers together. Right? Can two IP65 Blue Smart 5A be connected to one AGM battery at the same time and with the same parameters?
@Petoro, yes, it is acceptable to parallel-connect as many charge sources as you like to a single battery/battery bank so long as under no conditions do you exceed the battery's recommended maximum charge rate.
11 People are following this question.
