Steve avatar image
Steve asked
Victron 75/15 overcharging battery
Hi. So my alarm in motorhome was saying leisure battery was overcharging. A 120w panel and victron 75/15 charge controller as been powering up my leisure battery fine for around a month. I connected up to a spare battery and its going up to 15.1 before I disconnect it cause seems to much thanks steve
error
Steve avatar image Steve commented ·
So today its all working fine. CHarged 2 batters which went to float charging 3rd fine. Strange
spirou avatar image
spirou answered ·
Quite possibly switched itself to 24V mode. It happened to me once.
Don't think it possible for me to change volt from 12 to 24
rudykruger avatar image
rudykruger answered ·
What model charge controller? Under "Battery" in VictronConnect settings for the charge controller, what are your Battery Preset settings, Charge Voltage settings, Equalization settings.
Victron 75/15 mppt. Not smart no Bluetooth mppt
rudykruger avatar image rudykruger Steve commented ·
So it's a Bluesolar 75/15? If it was me I would want to see settings, since these controllers are programmable. The Bluetooth dongle is $50 or so and the VE Direct to USB cable is around $30. Batteries are expensive... https://www.amazon.com/dp/B01LZ6WTLW/ref=cm_sw_r_cp_apa_i_dTijEb8EB23VR
Steve avatar image Steve rudykruger commented ·
OK. Thanks for your help
peterowan avatar image
peterowan answered ·
Just to add a supplementary that my MPPT 75/15 BlueSolar also decided the world was a 24v one. The switch off / disconnect / cup of coffee / reconnect didnt work. Dongle arrived this morning and all is fine now ive reset it to 12v. From scanning the forum this does appear to be a recurring problem
trollan avatar image
trollan answered ·
Unfortunately I have the same victron MPPT controller and a 24v setup and today it kept spiking to 30+ volts even though it should not exceed 28.8 - it has the latest firmware. cannot keep using it if it continues to over charge the batteries
