susiboat avatar image
susiboat asked
CCGX Firmware 2.42 Beta AC and DC readings
CCGX Firmware 2.42 Beta The problem I have is the AC reading and DC reading i.e. when in normal inverting mode there’s no problem but when I use my generator the AC out put goes from 16 to 4 watts the DC goes up from say 80 watts to 160 when the battery’s are fully charged the reading are about the normal but when the water pump kicks in the reading on the DC go up which is ok but the AC output takes a dive from 16-20 to 4-0 watts I have checked this with previous version of firmware 2.41
CCGX Color Controlfirmware update
Hi @SUSIBOAT
these are calculated values, so they can be off a bit.
shubham avatar image shubham commented ·
Hi @Daniël Boekel (Victron Energy Staff)
could you please guide me as to where do I find the information: which parameters show measured values and which show calculated values?
Additional information:
Please find my system plan below (with energy meter EM24)
I am particulatly looking for the information on the following parameters:
Grid_L1, Grid_L2, Grid_L3
AC_consumption_L1, AC_consumption_L2, AC_consumption_L3
P_AC_PV_L1
PV_DC_couple_power
Battery_Power, Battery_Current, Battery_Voltage, Battery_SOC
VE_Bus_charge_Power
grid comes from grid meter
DC pv from MPPT
AC pv either from PV inverter or measuring device
battery: depends if you have CANbus battery, battery monitor or nothing.
the rest is calculated
