Can the EasySolar 48/5000 be mounted horizontally?
It has been designed to be mounted vertically. This helps to cool the machine passively.
If you were to mount it horizontally then the fans would most likely run more often or at lower loads than when mounted vertically.
I stand to be corrected, but I can't see that any harm would come from mounting it horizontally.
3 People are following this question.
