solcellespesialisten avatar image
BYD + Easysolar
Is the BYD Box PRO 13,5 kW compatible with Easysolar 48/5000 - 70-100 ?
EasySolar All-in-OneBYD
Hey; are you sure its 13.5? BYD is saying they don't have a 13.5;; probably you meant a 13.8? If so, could you edit your question for that? thanks!
porcini avatar image
porcini answered ·
Hello, yes it is (48V 13,8kWh Version). You can find more information here:
https://www.victronenergy.com/live/battery_compatibility:byd_b-box
Although is not listed there, dealers are listing victron inverters as compatible.
I have just updated that manual, and can confirm that it is compatible.
Anil Ghatikar avatar image Anil Ghatikar Guy Stewart (Victron Community Manager) ♦♦ ·
I think the manual further needs an update to include the new 3.5 KWH modules
That would almost be a whole new manual.
That is quite a different product to the rack mount units. As it is suitable for on-grid use ONLY, it is unlikely that it will be me who is working on it. Unless someone asks very nicely.
UPDATE - I was nicely asked, and the manual has now been updated with the full range of compatible BYD batteries.
solcellespesialisten answered ·
Thanks for clarifying. And by compatible, does that mean that the unit is more or less plug n play ready via CCGX presets, or compatible by user-defined programs?
The Easy Solar is best thought of a a Multiplus, MPPT and CCGX in the same box.
You will require the same configuration as that.
So best to get familiar with this document:
