Hello Victron community,
This is my first post and my first off grid system which I am still getting used to.
I have a Multiplus 24/3000/50, CCGX and six Northstar Blue NSB210FT. Now I know there are issues using these AGM batteries which require equalisation for 16 hours every two weeks.
I have tried the first equalisation today by flicking the switch on the multi which worked and went into equalisation mode but it seems to switch back to float after about an hour.
Is there a setting to increase the time?
Also to get the Multi to start equalisation I use the MK3 dongle and enabled equalisation in the VE configure but it mentioned โtubular plate batteriesโ, not sure if my batteries are tubular plate of not?
firmware on my Multi is 1910142 so assume it has the old microprocessor and that I canโt initiate Equalisation via the mobile app?
Any help is appreciate.
Thanks
John
