nickds avatar image
Can't see PV or AC Loads on AC coupled Quattro to Fronius
My Fronius Primo is showing 1,400W Output on the LED display, I have loads on in the house, but my CCGX is showing an AC load of 0, and no PV Yield (No icon even). However, the battery is charging a bit (434W) Any ideas what could be going wrong here?
CCGX Color ControlFronius
petajoule avatar image
petajoule answered ·
Judging from the observed flow of power, it looks like your Fronius Primo is connected to Victron AC-Out and working. All this works without the CCGX even being aware of the Fronius' existence. There just somehow magically is power inflow from AC-Out.
Now:
To make sure the CCGX is aware of the Fronius Primo, please check the documentation at https://www.victronenergy.com/live/ccgx:ccgx_fronius
Especially make sure the Fronius (its built-in datamanager) gets an IP in the local network and that you can access the web page of the datamanager.
If you can, then basically proceed as in section 2.2 of the link I sent above (Adding Fronius to the CCGX), after that the CCGX should be aware of the Fronius.
stxshadow avatar image
stxshadow answered ·
Did you tell your CCGX to search for a new PV Inverter ?
If so it should show the corresponding IP address.
Is ModBus TCP enabled at the Primo ?
Jens
