robnovotny avatar image
robnovotny asked
Indoor/outdoor thermostat (air temp) for Victron Connect?
Hi! We build camper vans and would love to add a thermostat or two to display indoor and outdoor temperatures via the Victron Connect app. Does Victron or 3rd-party have a Victron Connect device for this?
Temperature Sensortemperature
Justin Cook avatar image
Justin Cook answered ·
@robnovotny, unfortunately Victron does not offer indoor/outdoor air temperature measuring devices, but I will mention that the Smart BatterySense does a pretty decent job of measuring ambient temperature; that being said, they're designed to be attached to an actual surface and measure the temperature of that surface, so I'm not sure if they would work for you or not... They're the closest thing you'll find to what you're looking for in the spectrum of VictronConnect-compatible devices, however, if you can find a way to make them work.
Victron temperature sensor disambiguation table - which product supports which sensor
