dgorman avatar image
dgorman asked
BMV using lynx shunt and Lynx shunt
I’ve installed the lynx shunt and made my system use it vs my BMV. I then attaced the BMV shunt PCB to the lynx shunt and are sure the BMV settings has 1000A for the shunt size. I need to have the gauge display, however, I noticed the BMV is becoming more inaccurate as time goes on and it used to be right on the money. What is the voltage for the lynx shunt, the BMV was 50mv. Barring this set up, should I put another shunt in-line for the BMV? What are others doing?
lynx shunt
Hi @Dgorman
Did you compare current readings between the Lynx shunt and the BMV?
