Hello, when I select the 12-hour registration interval the interval is 2 hours and when I select 1 day the interval is 4 hours. I could check the graphs and the system summary.
You're right, I can duplicate that too. It may be a bug in that page, or even in the applied interval. If you could confirm which from your data it might help to sort it.
Thanks for you repply, I check data in two installations, one with interval 12hour and other with 24h, and the registers interval are 2 and 4 hours. Wich intallation have a different version of firmware 2.33 and 2.40.
Thank you @Enrique Marquez! Fixed in v2.41, see here:
https://www.victronenergy.com/blog/2019/12/20/venus-os-v2-41-fixing-byd-communications-and-more/
15 People are following this question.
