ron avatar image
ron asked
What cables do I need to connect Venus GX to other Victron parts?
I have just had a new Solar PV system installed. It uses a Victron Multiplus 24/5000 Inverter/Charger and a BMV712. I want to buy a Venus GX. Can someone tell me if all the cables etc. necessary to connect the system together are supplied with the Venus
Venus GX - VGX
Jan Zmrhala avatar image
Jan Zmrhala answered ·
Hello, with venus you don't get any cables. You need them buy extra. You get all the stuff to mount it on the wall, but no cables (only powercable with fuse). Just let me know here what parts do you have in your system (inverter, MPPT, battery and so on) to give you all cables you need.
ron avatar image ron commented ·
This is what I have had installed.
SCL Power 5 PopZS400 540Ah C100 Deep Cycle Lead Acid Batteries x12
Huber SCL MPPT 145/60 Solar Charge Controllers x2
Jinko 275Wp Polichrystalline Solar Modules x12
Victron Multiplus 24/5000 Inverter/Charger x1
Victron BMV 712
I am new to solar systems so I dont know a great deal about them yet, however I was a computer engineer so I am a bit of a techie.
Jan Zmrhala avatar image Jan Zmrhala ron commented ·
Hello, you will need:
1. MPPT to Venus (https://www.victronenergy.com/cables/ve.direct.cable) in case of regular victron MPPT (I don't know the huber)
2. battery to venus (temperature sensor - this was attatched to victron multiplus, if you don't have it anymore use https://www.victronenergy.co.za/accessories/temperature%20sensor%20qua%20pmp%20venus%20gx)
3. Multiplus to victron (regular ethernet cable)
4. BMV to Venus (https://www.victronenergy.com/cables/ve.direct.cable). I believe when you use this one, you don't need number 1 and 2.
IF you are now good with BMV than buy just one direct cable (https://www.victronenergy.com/cables/ve.direct.cable) and one ethernet cable (Regular RJ45 UTP cable) and you good to go. The direct cable connect to BMV and VE.Direct of Venus and ethernet cable - one end to multiplus other one to VE.Can of Venus)
kind regards
Hi @Ron,
The VenusGX manual shows what is included in the box, and what connections are required for various Victron devices.
ron avatar image
ron answered ·
Victron BMV 712
