Viktor avatar image
Scheme of the system with stabilizers and Fronius
I tried to describe my problem in a file with drawn diagrams of my system. Please see the attachment.
Question1.pdf
ESSvictron productsFronius
question1.pdf (135.6 KiB)
Rob Duthie avatar image
Rob Duthie answered ·
Hi
It will work just the readings on the CCGX are configured to read the Fronuis on the output so the load readings will be wrong, why do you need a stabilizer as the victron will stablize the output voltage as it acts like as UPS function anyway.
Regards
Rob D
NZ
3 comments Share
Hello, Rob.
Thank you fot your answer. I need stabilizer when my system just transfer power when grid presence, not for UPS mode.
But in standart connection I have trouble when solar inverter generate with full power, battery is charged and grid suddently off - i have an overload alarm on inverters and system has stops for several secounds. It error don't appear on VRM or in log-file. So, i need to separate solar inverter from the system when grid off, and connect it to output of Victron only when system work autonomuosly. I think that i can avoid this failure in this way. What do you think about this solution?
Hi
Yes it can be done the Fronuis will need to be setup to allow for this change over to the victrons output, there are settings in fronius to work off grid tied to another inverter output, remember there is delay time in start up etc for the Fronius inverter.
Not sure what happens when the Fronius output is much greater than the loads and or when the battery is fully charged etc does it back off or go into limiting mode?
I have do a test rig here with a Fronius and other inverters etc i could reconfigure and test etc.
So what is this stabilizer device type, model, operation etc?
The standard system should work as good. as this what have running at the moment
in this configuration but using another brand of inverter.
I will have to do some grid fail test to see what it does.
i know if i loss the grid the UPS mode kicks and starts carries on as normal.
Regards
Rob D
NZ
Hello, Rob.
I tried to describe the situation in the attachment. I would be very grateful if you could simulate this situation (with the Victron switch) on your test rig.
Thank you!
Victron Question.pdf
victron-question.pdf (251.4 KiB)
