gavia avatar image
gavia asked
MultiPlus 12/2000/80 50 120V #7 VE Bus BMS without assistant
I have the subject inverter/charger installed on a LI system, have updtaed VE Flash to the latest 90.05.153, downloaded the correct VFF for the Inverter charger, have loaded the assistant on SYs Config, all to no avail to delete the continuous error code.
The Bus BMS does not indicate it is enabled. I have triple checked all wiring as well.
Any suggestions?
battery charging
Hi @Gavia
sorry for missing this question.
I guess you've resolved it since?
if not:
-what components are you using? how are they connected and what firmware and assistants are on the units?
