Sanat Rath avatar image
Sanat Rath asked
charging 24 v 11 amp lithium ion battery
SOLAR SETUP TO CHARGE LITHIUM ION BATTERIES (24v 11a)
I want to start a new project. I am completely new in this field. My only concern is that the charging current should not exceed 4 amps in any manner. I have even heard that the voltage should not exceed 30 volts.
Kindly provide me inputs on the same especially about the solar panel rating and mppt charge controller ratings which I should use.
Thanks
Sanat
MPPT ControllersSolar Panel
Justin Cook avatar image
Justin Cook answered ·
@Sanat Rath, all of Victron's SmartSolar MPPTs have completely customizable charge profiles, including voltage as well as max charge current. So, as an example, you could easily hook 2 or 300 watts of PV input into a SmartSolar MPPT 75/15; when you connect it to your battery bank, the MPPT will auto-range to your battery voltage at 24v nominal (which will typically leave you charging at around 27-28v) and you can use the VictronConnect app to set the MPPT max charge current to 4A as desired, rather than the 15A default charge rate.
MPPT Product Page
MPPT Error codes
