geomz avatar image
geomz asked
Why is MPPT charge voltage 30V in a 24V ESS system?
I have 2 100/30 Smartsolar MPPTs integrates with a Quattro 5000 into an ESS, running on 24V lithium batteries.
I understand that with ESS the inverter takes control of the charging profile from the MPPTs.
However, I was looking under “Networked Operation” section of my MPPTs and noticed the following screenshot
Why/how is charge voltage 30V?!?
Nothing anywhere is set to that voltage
Not the MPPTs locally
Not the bmv’s battery settings
Not the inverter veconfig settings
So I’m confused as to where this is coming from and how/why.
I doesn’t appear to be causing any issues as charging appear normal, but...
Should I be concerned about this?
Thanks in advance
MPPT ControllersESSvoltage
The voltage of the MPPT must be set with a margin above the Multi/System Voltage so that it will produce and push (so the PV is the priority charge/power source), and/or allows for PV export.
This offset voltage value is set by the DVCC/External control system, and is not user adjustable. Which is why it is not shown to you.
I understand that it could lead to some confusion, and will pass it along to see if this can be made clearer/less scary/removed from the user interface.
As you have seen the actual battery voltage is controlled by the External Control system so that it will not overcharge the batteries.
For now, it is normal, and you should not be concerned.
geomz avatar image geomz commented ·
Thank you @Guy! That makes perfect sense and I appreciate your explaining it to me :)
thanar avatar image thanar commented ·
This is definitely perplexing. I am also getting a bit scared by seeing this reading. Why not report the target charging voltage instead? And -while we're at it- is there any way on an ESS system to get the target charging voltage? Apart from using VE remote to download the configuration file from the inverter and run it through VEconfigure?
