randolf avatar image
randolf asked
SmartSolar 75/15 SOC Calc Raspberry Pi
Good Evening Victron Community,
I have been running a tiny setup with a single SmartSolar 75/15 and a 65Ah Lead Acid battery for the past few days.
The latest addition to the setup was a RaspberryPi running VenusOS that connects to the SmartSolar 75/15.
Would it be possible in future releases to Calculate SOC of the battery (if given a Capacity in Ah) for systems where all loads pass through the MPPT load output and where all charging happens through the MPPT?
Additionally is there a way to remove the AC Input and Loads symbols for these DC only Systems?
Kind Regards
Randolf Wenhold
MPPT ControllersRaspberry PiSOC
ossi avatar image
ossi answered ·
Hi Randolf
to display the SOC it must be measured first, therefor you will need the BMV7xx first which includes a shunt.
without a shunt it is mostly SOC guessing.
For the display, try using mobile home slide by swiping over home screen
randolf avatar image randolf commented ·
Hi Ossi,
Thanks for your reply.
Is there a way to remove tiles from the Mobile Home View?
I have read that it is possible to add a custom logo.
Kind Regards
Randolf
